When it comes to gaming, you always want to give it your all. This means more time, more effort, and more power. However, devices weren’t built to run forever, and you might need to take a break once that dreaded low battery notification comes up. While you might be able to simply recharge and keep going, it’s also important to know that constantly charging and depleting your battery fully will damage the battery.
Fortunately, the innovative minds at REDMAGIC have found a way to get around the obstacle of a low battery affecting your longer gaming sessions, all while protecting and preserving your battery health.
In this blog article, we take a look at the REDMAGIC Charge Separation feature and how it can help you optimize your gameplay and safeguard your battery life. For now, let’s understand the basics of what charge separation is and how it works.
What Is Charge Separation?
REDMAGIC’s Charge Separation feature, also known as bypass charging, powers your device directly from the power source without affecting the battery. As the name suggests, the power bypasses your battery and funnels straight to the device’s internal components, using only as much power as needed. When using Charge Separation, your battery level will remain unchanged while plugged in, drawing power directly from the circuit instead of the battery. So, why is it such a big deal for mobile gaming?
Why Do I Need Charge Separation on a Gaming Phone?
Battery degradation is a serious problem for mobile gamers, as frequent charging depletes your battery’s integrity.  A gaming smartphone is bound to consume much more battery and needs a lot more power for its intensive processing. This means that gaming phones have to be equipped with larger batteries and dedicated battery protection.
Using Charge Separation allows you to preserve your battery’s health while still being able to play for extended periods. By enabling this feature, you can plug your device in and game for hours without your battery being charged, degraded, or overheating.
However, Charge Separation isn’t only useful for heavy gaming; it can also protect your battery during other intensive processing tasks. If you frequently use your video editing, streaming, or any other power-hungry process, the feature will come in handy to preserve your battery life. Anyone who values the longevity of their device will invest in bypass charging. Now, to drive that point further, let’s look at some of the advantages of REDMAGIC’s Charge Separation.
Benefits of REDMAGIC’s Charge Separation
At REDMAGIC, we strive to give our fans the best quality and assurance. However, we cannot always bend the laws of physics, which means that we have to get creative with our engineering to make gaming devices that last longer, perform better, and improve every experience. These are some of the main benefits of our Charge Separation feature:
  • Performance Elevation: A major benefit of Charge Separation is a boosted performance. Whether you’re gaming or doing any other task, extending your device’s battery life without affecting the battery leads to smoother performance and less thermal throttling despite several hours of activity.
  • Battery Integrity: Constant charging and depletion of your battery will damage its components. The general rule is to keep your device between 20 and 80% battery at all times. By using Charge Separation, you allow your battery to sit idle without any excess strain.
  • Device Longevity: Most smartphones are meant to last a few years before seeing any signs of degradation. However, this is dependent on how you treat your device and safeguard important components, like the battery. Charge Separation prolongs your device’s lifespan and overall health.
  • Reduce Heat: Every device generates heat, especially when used over a long period of time. Most of this heat will come from your battery usage. Charge Separation reduces the amount of heat your device generates by leaving the battery alone, allowing your phone to remain cooler. This improves comfort when holding the device, reduces thermal throttling, and prevents the risk of overheating damage.
While there are several ways to extend and protect your battery life, REDMAGIC’s Charge Separation provides an optimized and efficient solution that won’t compromise your gaming or daily usage experience. This feature ensures a healthy battery life without affecting performance or usage; if anything, it only serves to amplify it.
How Do I Switch On Charge Separation?
Charge Separation is a very simple feature to toggle on or off on your REDMAGIC device. Simply follow these instructions to activate:
  1. Open Settings
  2. Scroll down and select Battery Menu
  3. Find and toggle on Charge Separation
Users can also choose to adjust the charging percentage, limiting the battery capacity according to their needs and battery health. Once this percentage is reached, the phone will automatically switch to being powered directly by the power source, and the battery will remain untouched.
Smart Battery Protection
When it comes to pioneering designs and features, REDMAGIC always tries to stay ahead of the curve by applying a user-centric approach. We aim to provide solutions that make every gaming experience better, more optimized, and more secure. While bypass charging itself may not be an entirely new concept, Charge Separation is fine-tuned in our devices to ensure performance that never falters and battery protection that never fails.
