REDMAGIC 8 Pro Is a Born Winner
Certain features set a gaming smartphone apart from the ordinary smartphone, such as the RGB lights that add a unique gamer aesthetic. To take things a step further, there are special modifications that make one gaming smartphone a better option than the next, like the classic 20 000 RPM turbo fan that’s a part of the REDMAGIC powerhouse. When it comes to the REDMAGIC 8 Pro, a combination of hardware and design improvements make it a one-of-a-kind gaming smartphone that’s built for the win.
A Battery Made for Endurance
Of all the REDMAGIC gaming smartphone models, this one has the largest dual-cell battery yet. The 6000 mAh battery can provide up to 8.28 hours of battery life for uninterrupted gaming. Plus a 65W fast charge capability gets you right back in the game after just 43 minutes of charging, according to lab tests.
Bring on the Heat
As part of the cooling mechanism of the REDMAGIC 8 Pro, there are 10 layers of the ICE 11.0 Multi-Dimensional Cooling System, one of which is the biggest 3D Vapor Chamber in the gaming smartphone industry. It prevents the device from overheating and eventually slowing down during extended hours of intense gaming.
A Screen Like No Other
The screen on the REDMAGIC 8 Pro is truly one of a kind. It gives the gamer a 6.8-inch panel with no punch holes or notches for a fully immersive view of the battleground. It’s sufficiently bright at 1300 nits and can provide a clear display if you’re gaming outside in the sunlight. The additional layer of graphene under the screen will help keep the device running at ice-cold temperatures during situations like this. Not only is the screen beautiful and incredibly cool, but it’s also really powerful with a 960 Hz multi-finger touch sampling rate to let you make very quick and accurate movements.
Frame Stability Guaranteed
The quick Snapdragon 8 Gen 2 processor delivers super smooth gameplay by providing a 120 Hz screen refresh rate to ensure frame stability during intense games with lots of movement. You’ll be able to aim and fire with unbelievable precision to beat more levels.
Get Yours and Up Your Game
Don’t forget that you can get $30 off your purchase when you use the early bird discount voucher. Get your hands on the REDMAGIC 8 Pro and upgrade your gaming smartphone today.
