Did You Buy a Throttling Nightmare? Upgrade Your Phone with the Cooler 8 Pro
So, you’ve spent around $1,200 on the latest smartphone, and now it turns into a mini heater every time you try to use it? We’ve all been there. Despite the flashy credentials and “pro” performance of most high-end, titanium-clad smartphones, getting around overheating is one flaw that always seems to slip through the cracks, so now you’re left playing hot potato instead of Genshin Impact
This flaw exists because most mainstream smartphones boast about cooling capabilities, only to go ahead and trap the heat inside their premium glass and metal frames. They also tend to rely solely on passive cooling techniques to keep the temperature down, which is woefully hopeless when you’re trying to clear the arena in a demanding game like Warzone Mobile.
A weaker cooling system translates to slower processing, plummeting frame rates, and disastrous throttling, with your screen suddenly dimming itself to 50% to save itself. So, while you stare at a suddenly dim, lagging, and overly-priced screen, let’s talk about how we can make this whole situation much better.
A Much Cooler Solution
Cooling technology has been around for decades, mostly being stuffed away in PCs and then consoles. However, at REDMAGIC, we broke into the market fully loaded with the first smartphone to use a built-in fan. Since then, we’ve been at the forefront of innovative cooling tech for a more demanding mobile gaming audience. So, when it comes to effective cooling solutions, you can trust that we know what we’re talking about.
Today, we’ll be focusing on the extensive power of the REDMAGIC Cryo Cooler 8 Pro, the revolutionary cooler that’s going to solve all your throttling problems. As its name suggests, coolers are small devices that can be attached to the back of your smartphone to keep it, well, cool. Now, you might see the flashy RGB lights and think it’s just a “fun little gamer accessory”, but we don’t do smoke and mirrors at REDMAGIC.
The Cryo Cooler 8 Pro was built to upgrade your hardware, effectively manage heat, and prioritize performance. For your mainstream non-gaming smartphone, this is an essential tool that will keep your phone from spontaneously bursting into flames, figuratively at least.
While other brands use passive cooling, where heat is often removed solely through the thermal conductivity difference between materials, we tend to opt for the more engaging active cooling angle. Our gaming smartphones are already operating at 100% thermal optimization due to integrated turbo fans and liquid cooling systems. Naturally, we try to cover all bases and add passive methods like Graphene layering and vapor chambers as well, forming a comprehensive, built-in cooling solution.
However, we couldn’t just leave everyone else behind with lagging frame rates and overheating metal boxes. Enter the Cryo Cooler 8 Pro, because everyone deserves active cooling power that actually works. Now, let’s get into the nerdy bit and go over the technical specs of the cooler.
Engineering Absolute Zero
Before we get into the details, let’s get a brief overview of all the Cryo Cooler 8 Pro’s basic specifications, so we know what we’re dealing with:
Dimensions
70 x 63 x 31mm
Maximum Power Output
36W
Weight
113g
Magnetic Suction
14N
What’s in the Box?
1 x REDMAGIC Cryo Cooler 8 Pro
1 x Magnetic Sheet
1 x Dual USB-C Data Cable
1 x REDMAGIC Mora Limited Edition Sticker
1 x User Manual
The Cryo Cooler 8 Pro was designed to provide efficient, peak thermal control in a variety of situations. Armed with an 8th-generation COLDLNG architecture, the Cooler 8 Pro ensures 30% better cooling efficiency, while a 36W peak output rapidly reduces core thermals, inviting an 80°C load temperature drop and up to 50°C temperature drops under no-load conditions.
The cooler also features advanced semiconductor cooling parts, more specifically, 124 high-density PN junction pairs combined with a large 1,640 mm² TEC cooling engine for stronger heat absorption. This significantly increases cooling capacity and speeds for up to 130% improved performance over the previous generation of cooling chips.
Under controlled REDMAGIC laboratory conditions, we also compared the Cryo Cooler 8 Pro to other products with similar cooling capacities and found that it easily reduced a 40°C heat source to 25°C in overclock mode. Moving towards cooling hardware, the cooler also comes with an 11-blade, 6,200 RPM turbo fan made with an aerospace-grade aluminum heatsink for faster heat dissipation, intense airflow, and superior thermal conduction as soon as heat begins to build.
Using intelligent REDMAGIC AI control and a precision NTC sensor, the cooler also provides real-time temperature monitoring that automatically adjusts cooling output accordingly to prevent condensation damage. Just above the cooling fins, a smart temperature-sensitive layer changes colors to visually display cooling status.
To ensure secure cooling, the Cryo Cooler 8 Pro uses a large-area N52 magnet for rock-solid attachment, even during intense gaming or outdoor filming. With 14N magnetic suction power, the cooler stays firmly stuck to your device for effortless and secure handling.
Moreover, the cooler has a versatile 2-in-1 optional design that allows you to effortlessly switch between a magnetic hold and a dedicated Android back clip with a 1/4-inch universal thread to directly mount tripods and streaming rigs. This makes it the ideal cooler for streamers, gamers, and regular users alike.
The Cooler 8 Pro design is also compatible with MagSafe Apple and Android smartphones and tablets, allowing you to seamlessly snap it on any device, even if you have to use the included magnetic sticker instead. This gives you clean and instant cooling without any fuss.
Adding to its flexibility, the cooler is also designed to thrive in almost every situation and works wonders to prevent overheating during extended gaming sessions, keep your phone cool while charging, or manage heat while watching videos or livestreaming. However, we don’t just focus on the technical specs at REDMAGIC because we know that your gamer aesthetic is just as important.
Where Form Meets Function
While our Cryo Cooler 8 Pro effortlessly reduces core temperatures and sets a new standard in mobile cooling innovation, it doesn’t ever shy away from being stylish at the same time. Most smartphones bore you with plain glass exteriors with no personality; however, the Cryo Cooler 8 Pro gives you a unique, premium carbon fiber textured look that screams eccentric gamer energy.
The Cooler 8 Pro is much more than just a pretty face, though. The cooler is designed to be compact and lightweight, making it easier to handle and move around with. It also uses a dedicated vertical 3D airflow design that pushes heat away from your hands to keep your grip cool and comfortable, all while staying whisper-silent at lower than 36dB sound output.
Draped in an upgraded Kevlar-textured finish with a sleek metal feel, the cooler looks sharper, bolder, and more hardcore, allowing you to truly stand out. The customizable honeycomb RGB grille also features multiple adjustable lighting modes for an effortless gamer aesthetic. You can also easily adjust cooling levels or customize RGB lighting effects through the Goper app. Now, let’s see how the cooler managed our stress testing.
Surviving the REDMAGIC Labs
At REDMAGIC, we don’t just talk the talk, which is why we submit all our products to rigorous quality assurance testing at our labs. We know that the average gamer is probably going to be putting our devices through the wringer with hours of grinding, sweaty palms, and maybe even a few bouts of raging. So, we beat you to the punch and push our devices through enough stress tests to ensure peak performance, durability, and integrity.
During full-frame, high-speed gaming, a smartphone’s central heat source typically remains within 10W. So, to get our load reduction numbers for the Cooler 8 Pro, we started with a constant 10W heat source at 95°C. After 20 minutes of cooling using the REDMAGIC 8 Pro in overclock mode, we measured the surface temperature drop to 15°C, giving us the basis for our 80°C load reduction specs.
Apart from cooling performance, the cooler was also subject to several durability tests to see how solid it remained. Fortunately, the Cooler 8 Pro easily stayed in one piece, stayed securely attached to an iPhone, and survived up to 10,000 Type-C port durability cycles. Take a look at our excruciating stress tests that the Cryo Cooler 8 Pro gracefully survived below.
We mercilessly pushed the cooler through several cycles of torture, from ESD protection tests, 1-meter drop tests, and 2 hours of abrasion testing to extreme stress tests of more than 6 hours of non-stop operation. Ultimately, the Cryo Cooler 8 Pro came out on top as a victor, establishing itself as the premium choice for cooling excellence.
In his YouTube review of the Cryo Cooler 8 Pro, Kingmi Mobile was heavily impressed by the cooler’s power output and put it through a freezing and load performance test as well. After around a minute, the water droplets he left on the cooler were already frozen solid.
Sourced from Kingmi Mobile
He then used a load tester at maximum power with the surface temperature of 68°C. After applying the cooler, the temperature stayed at a stable level of around 25°C, providing effective heat dissipation.
Getting Ahead of the Fire Hazard
We all love the latest technologies, standing in long lines and counting down every launch. However, gamers who value performance need to focus on what they’re actually waiting for. Despite the latest specs, not every flagship phone is built to be a gaming phone. The Cyro Cooler 8 Pro sweeps in to save the day with effective cooling power that keeps your phone from throttling, boosts processing efficiency, and provides a comfortable gaming experience.
Like a great man once said, “With great power comes great responsibility,” so allow yourself to be both with the Cyro Cooler 8 Pro and manage your heat responsibly with exceptional power to boot. Don’t let the limitations of your non-gaming smartphone leave you lagging behind.
"Stop Thermal Throttling – Shop the Cryo Cooler 8 Pro"
Q: What is the Cryo Cooler 8 Pro?
A: The Cryo Cooler 8 Pro is one of REDMAGIC’s latest innovative coolers that easily and securely attaches to a variety of smartphones and tablets to ensure effective, rapid, and lasting cooling and thermal management.
Q: What are some of the key features of the Cryo Cooler 8 Pro?
A: The Cryo Cooler 8 Pro features 36W power output and uses an 8th-generation COLDLNG architecture to ensure flagship cooling with a 30% performance boost, a  -25°C temperature drop, and an 80°C load temperature drop.
An 11-blade, 6,200 RPM turbo fan and an aerospace-grade aluminum heatsink also provide faster heat dissipation, while intelligent AI temperature control ensures real-time thermal monitoring to prevent condensation damage.
It also uses a 2-in-1 magnetic and back-clip feature for flexible attachment options for iPhones, Androids, and streaming rigs.
Q: Can the Cryo Cooler 8 Pro be used with other non-gaming phones?
A: Yes, the Cryo Cooler 8 Pro is seamlessly compatible with MagSafe iPhones, Androids, and other smartphones or tablets. It also includes a magnetic sticker for devices without a MagSafe feature.
Q: What’s the maximum temperature drop achieved using the Cryo Cooler 8 Pro?
A: The maximum temperature drop Cryo Cooler 8 Pro achieves is -25°C.
