Whether it's the last-second clutch to save the game or finally unlocking a new weapon, Call of Duty Mobile can get intense real fast. At REDMAGIC, we try to stay ahead of the curve when it comes to popular gaming titles to ensure that our fans are always equipped for victory, no matter how dire the arena can be. So, to put your mind at ease when you load Call of Duty Mobile up on your REDMAGIC device, we've got a few pointers to help you keep your team alive and maintain the perfect killstreak.
Answer the Call
Call of Duty Mobile is a popular multiplayer battle royale game developed by TiMi Studio Group and published by Activision for Android and iOS. The game pushes players to the limit, demanding fast reflexes, cooperation, and strategic planning to stay alive and reign victorious. Whether you're grinding Ranked, chasing Legendary status, or pushing for tournament-level consistency, small advantages can make a big difference.
A year after its 2019 release, the game had already racked up over 300 million downloads worldwide. Today, activeplayer.io has estimated that 70% or 210 million people are actively playing CODM. Fortunately, REDMAGIC devices are built for gamers, with features designed to enhance gameplay.
For ParkerTheSlayer, CODM makes the most sense with REDMAGIC. In his YouTube review, Parker tested out the 11S Pro playing Call of Duty Mobile, stating that he couldn't really see himself switching over to any other phone brand when it came to playing COD Mobile because "REDMAGIC truly does have everything that I need as a mobile gamer."
Sourced from ParkerTheSlayer
So, let's put that theory to the test and see how we've pushed the bar for CODM players. Here are the top five REDMAGIC features that you should be using to get the most out of every CODM match:
1. Feel the Trigger
Easily one of the standout features of a REDMAGIC device for gaming is the shoulder-trigger input. Every CODM player also knows the value of precious screen space when you're in the heat of battle. That's why REDMAGIC shoulder triggers add on an extra layer of input control, especially for Ranked matches where speed and agility are critical.
Placed strategically on the edge of the device for a comfortable grip and easier control, these shoulder triggers offer a lightning-fast 520Hz touch sampling rate for instant responses and precision that keep you immersed in the game.
You can easily customize your REDMAGIC shoulder triggers as well, allowing you to disable select triggers and adjust input actions according to your needs. With additional inputs for your game, you can also separate critical actions from your main touch controls, allowing you to multitask and perform more complex actions.
For CODM players, you could also add different Fire triggers to the mechanic to improve aiming accuracy and speed. You can map a trigger to improve your Aim Down Sights (ADS) speed to reduce random bullet spread and push your Quick Scoping skills to the max, or select a trigger for Hip or Auto Fire shooting modes to ensure rapid and precise control.
Quick Benefits:
  • Frees up screen space for comfortably spaced inputs.
  • Rapid and precise responses to improve your response times, aim, and control.
  • Console-like feel for added comfort.
  • Competitive control layout during the game.
2. Amplify Your Audio
To stay ahead in CODM, you need to be aware of your surroundings at all times. This means that improved audio helps your situational awareness, keeping you from being a one-shot target. In your REDMAGIC plugin library, you'll find a whole list of plugin tools to improve gameplay across several games. For now, we'll focus on Sound Equalizer. With this mode enabled, CODM players can adjust the level or amplitude of specific frequencies for a clear and balanced sound output. This helps to enhance audio cues, allowing you to hear footsteps more clearly when an enemy is about to ambush.
Quick Benefits:
  • Seamless and high-quality custom audio as you play.
  • Enemy detection by allowing you to hear footsteps and audio cues more clearly.
  • Situational awareness in the game.
  • Better strategy planning with your team.
3. Optimize with Energy Cube
The REDMAGIC Energy Cube center allows you to adjust and optimize performance settings in real time through Game Space or in the gaming overlay. This hub allows CODM players to reduce overheating and ensure stable Frames Per Second during the game. This will provide better overall performance during longer CODM gaming sessions, giving you the upper edge for your Legendary Grind with consistent and reliable gameplay.
In the Energy Cube, you can customize display, graphics, performance modes, and GPU settings. However, this is also the prime spot to optimize your gameplay for the long haul. With our upgraded Energy Cube 3.0, our latest REDMAGIC devices use our proprietary hardware-software optimization engine to dynamically allocate CPU, GPU, memory, cooling, and touch resources in real time according to each game. This ensures higher FPS stability and faster responsiveness, all while consuming less power, boosting performance, and generating less heat.
In CODM, your agility means everything, which is why it helps greatly to have an in-game center to redirect resources towards gameplay rather than unnecessary background activity, ensuring seamless frame rates and smooth gameplay.
Quick Benefits:
  • Allocates resources for optimal gameplay.
  • Control over performance modes, touch input speeds, and stabilization in real time.
  • Stable frame rates and buttery graphics.
  • Longer gaming sessions.
4. Improve Your Target
Every CODM player knows that their eyes need to be on target at all times. In a fast-paced shooter game, it's easy to lose track of what you need to be aiming for. To ensure superior visibility, CODM players can use our Crosshair Overlay plugin which adds a center target overlay on your screen. Designed specifically for first-person shooter games like CODM, it gives you the opportunity to improve your aiming accuracy. A Quick Hide option also places a floating button at the center of the screen; when pressed, it hides the crosshair, and pressing it again brings it back.
While we have to stress that this feature won't replace good mechanics, it can help players improve their muscle memory and targeting consistency with a constant visual reference. This becomes especially useful when practicing hip-fire engagements, quick-scoping techniques, or tracking moving targets.
Quick Benefits:
  • Visual and aiming clarity, even in harsh in-game lighting conditions.
  • Consistent visual experience as you play.
  • Assists with target tracking.
5. The Hunt Is On
Built to customize the way you experience the game, Hunter Mode adds a fun visual overlay to your screen that changes the entire vibe of the game. By inverting colors, reducing color distractions, enhancing vision in darker areas, or even turning your game into an oil painting, Hunter Mode uses different filters and styles to put a stunning twist on your gameplay.
Visual clarity is a big part of winning in CODM, and each player approaches the game differently with different visual needs. With Hunter Mode enabled, you can experience the game differently, allowing you to test your skills out in a different visual terrain.
Quick Benefits:
  1. Stunning visual overlays and filters.
  2. Precision and clarity in different visual styles.
  3. Reduces visual distractions that might catch your eye in the field.
Dominate the Lobby with REDMAGIC
Victory in Call of Duty: Mobile isn't just about having quick reflexes; it's also about taking advantage of every weapon in your arsenal. REDMAGIC's gaming-focused features and plugins are designed to help you react faster, hear more clearly, optimize performance, improve accuracy, and see everything with clarity.
With tactical 520Hz shoulder triggers, amplified sound and visuals, and unique gaming centers for customized and optimized gameplay, REDMAGIC gives every CODM player a complete toolkit for taking their game to the next level. We've already armed you with enough to win, now you just have to go out there and do it.
REDMAGIC 11S Pro
From CA$1,149.00
From CA$1,149.00
