Reddit FAQ: REDMAGIC 11S Pro Battery, Protective Cases, and Cooler Recommendations
(May 2026)
We truly value building a sincere and engaging connection with our fans at REDMAGIC. To stay connected and informed, we regularly check in on Reddit to understand your most important concerns and questions so that we can offer the best solutions and answers. Below, you'll find some of the main questions we’ve seen pop up on our timeline recently.
  1. What Are the Battery Specs for the New REDMAGIC 11S Pro?
  2. Are REDMAGIC Devices Good As Daily Drivers?
  3. What Type of Protective Case Should I Get for the REDMAGIC 10 Pro?
  4. What Are the Best Cooler Options for the REDMAGIC 11 Pro?
  5. When Is the Expected Release Date for the REDMAGIC 11S Pro?
What Are the Battery Specs for the REDMAGIC 11S Pro?
Since the announcement of its launch, many fans have asked about the specific battery capacity of the REDMAGIC 11S Pro, like u/UnlimitedHalo. We can put your doubts at ease now by stating that the REDMAGIC 11S Pro will feature a 7,500mAh battery capacity, alongside pioneering wired and wireless 80W charging, two-way charging, and Charge Separation protection.
This is a common question from several users on Reddit, particularly focusing on connectivity, screen expansion, battery life, and cooling capacity. Today, we can answer u/GardenImaginary4637 directly and say yes, our REDMAGIC devices are primed for gameplay, which also makes them superior smartphones for your day-to-day activities. We encourage more fans to use our devices daily as they’re equipped with high-performance processing for various tasks, including editing, content creation, streaming, and much more.
In terms of endurance, our devices are fitted with large battery capacities and versatile wired and wireless fast charging options, keeping you powered up and ready to go. This makes our devices ideal for travelers, students, or hybrid working environments.
Many of our devices also allow second-screen expansion to improve your working situation or streaming capabilities, alongside strong, stable Wi-Fi and Bluetooth connectivity support. In fact, several of the positive replies to this Reddit question came from fans with REDMAGIC devices who can attest to their versatility and compatibility with everyday life.
Finding the right protective case for your device can be challenging with so many options available. On Reddit, u/Few_Cantaloupe_6082 asked this particular question with a focus on the REDMAGIC 10S Pro. Now, it’s important to note that REDMAGIC stocks protective cases and screen guards for all our gaming phones.
Ideally, the best protective casing option for the 10S Pro would be the REDMAGIC 10 Pro Series Protective Case, which provides 3D protection that effectively absorbs impact from drops for comprehensive protection. It also features a stainless-steel inlay with a built-in strong magnetic core for secure attachment of a cooler. The cover is ergonomic, lightweight, soft-to-touch, and features a 3D glacier grid pattern design. It is compatible with the REDMAGIC 10S Pro and 10 Pro phones.
Alternatively, you could opt for the REDMAGIC 10 Pro Series Cooling Protective Case with an external REDMAGIC 3rd Generation unique carbon steel magnet, cold window hollow design, and 3D protection to absorb impact from falls.
Coolers are game-changing devices that help gaming devices dissipate heat faster and prevent thermal throttling. In this particular instance, u/PushFine698 on Reddit asked around for a few recommendations for an 11 Pro case that would prevent their phone from overheating during PC or Switch gameplay.
For the 11 Pro, we recommend using the REDMAGIC Cryo Cooler 8 Pro, a 36W high-power cooling that chills devices down to -25°C and features an 11-blade, 6200 RPM turbo fan, with an aerospace-grade aluminum heatsink for faster heat dissipation. With both magnetic attachment and a back-clip design, this cooler gives you added versatility, alongside the 8th-Gen COLDLNG architecture cooling with a 30% performance boost, an 80°C load temperature drop, and smart AI temperature control.
The REDMAGIC 11S Pro is our latest flagship powerhouse to be launched and features the leading version of the Snapdragon 8 Elite Gen 5 chipset, an upgraded AquaCore liquid cooling system, a 7,500mAh battery with 80W wired and wireless charging, and a stunning 144Hz refresh rate and AMOLED display. Our eager fans, like u/Famous-Friendship134 who has been asking for all the deets, can now rest easy knowing that the launch announcement for the 11S Pro will be on May 27 at 8 AM EDT. Here, we’ll be sharing the full specs of the phone with our fans, talking about the expected price, and giving you a final release date for the elite flagship.
We hope this article has offered helpful solutions for your current concerns. If you still have any unresolved issues, feel free to contact us directly. For additional support, please reach out to our support team, and we will respond promptly.
REDMAGIC 11S Pro
From CA$1,149.00
From CA$1,149.00
